Getting slow-mo footage to run at normal speed (59.94 at 29.97)
Jules Stevens
on Jan 27, 2014 at 4:15:33 pm
Hello,
I recently shoot footage at 59.94 frames a second at 1080p. I converted it to 29.97 in cinema tools and imported it into FCP. In a timeline set to a frame rate of 29.97 I have beautiful slow-motion.
However, I want to have some of the footage play at normal speed, so I set the speed of the clips to 200%.
The footage does not run smoothly - it looks speed up and jerky like a old movie - clearly it is running too fast.
I don't understand, as surely this footage was shot at half speed, so to make it normal again I should double it.
Thoughts please!
Shane Ross
Re: Getting slow-mo footage to run at normal speed (59.94 at 29.97)
on Jan 27, 2014 at 5:11:52 pm
This is why I duplicate clips before I run Cinema Tools on it, so I have one copy running at normal speed.
Convert that clip from the master camera backup to ProRes, and 29.97 if you can (use Compressor)...and see how that looks.
Shane
Little Frog Post
