Cheap analog capture card for FCP7.
Karel Voners
on Jan 26, 2014 at 6:12:12 pm
Hi all,
I need to capture some VHS tapes (couple of 100). I want to have the end result in SD Prores HQ.
Are there any old capture cards that I can pick up and use for this? One that has composite of s-video in.
Does anyone have any suggestions?
PCI-X or PCI-E, doesn't matter I think.
Found these one on ebay:
Blackmagic Decklink HD Extreme + Breakout Cable + Software:
http://www.benl.ebay.be/itm/111261595124?ssPageName=STRK:MEWAX:IT&_trksid=p...
Or
AJA Kona-LH 12-Bit HD and SD Video Editing and Graphics PCI-X
http://www.benl.ebay.be/itm/111233447467?ssPageName=STRK:MEWAX:IT&_trksid=p...
Difficult to find user manuals of these legacy cards.
Cheers!
K.
Shane Ross
Re: Cheap analog capture card for FCP7.
on Jan 26, 2014 at 6:48:20 pm
[Karel Voners] "PCI-X or PCI-E, doesn't matter I think."
It does matter. This is pretty important. These are different connections. Are you running a G5, or a MacPro?
This card is cheaper than both the ones listed, and does what you need:
http://www.blackmagicdesign.com/products/intensity
Although ProRes HQ for VHS? that's overkill. The quality won't improve at all over ProREs 422. Only increase you'll see is file size.
Shane
Little Frog Post
Karel Voners
on Jan 26, 2014 at 7:05:00 pm
I'm running hackintosh so I got PCI but no PCI-X. So it does matter like you say.
But the newer blackmagic solutions start at 200$, much more then the 90$ Blackmagic Decklink on ebay...
Or am I missing something?
Cheers!
K.
Shane Ross
on Jan 26, 2014 at 11:52:18 pm
PCI? Not PCI-X nor PCIe?
Shane
Little Frog Post
Steve Eisen
on Jan 27, 2014 at 2:22:45 am
[Karel Voners] "I'm running hackintosh"
Your gonna need a hackincard. I've never seen one.
If your computer has firewire, you can use a dv camcorder to capture to DV format.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Creative Pro Users Group
Shane Ross
on Jan 27, 2014 at 2:57:19 am
Not really. My friend has a Hackintosh running a Decklink Extreme. Cut a doc feature with it.
Shane
Little Frog Post
