Creating a prores 422 from a 4444 is causing increased contrast and saturation
Mark Payne
on Jan 19, 2014 at 2:07:47 pm
Hi everyone,
I have a debut short that has been taken up for distribution.
The company require an apple prores 422.
I have a lovely 4444 copy, but when I take it into FCP7 and export, I'm getting a version with higher contrast and saturation. As a test I also tried importing an h264 and outputting it in prores 422 and the same increase in contrast and saturation took place.
(This is comparing all versions in quicktime on same screen side by side so its def not a monitor issue)
Presume I'm doing something wrong!
I'm now really behind on producing the deliverables.
Can anyone help and point me in the right direction?
Cheers,
Mark
Nick Meyers
Re: Creating a prores 422 from a 4444 is causing increased contrast and saturation
on Jan 20, 2014 at 10:32:09 am
avoid going though FCP to do this.
use Quicktime PLayer 7, Compressor, or Mpeg Streamclip
nick
Mark Payne
on Jan 20, 2014 at 1:18:39 pm
Thanks Nick, I'm on the case trying this. Much appreciated.
Mark
Doug Johnson
on Jan 22, 2014 at 7:52:43 pm
Mark, did you find a solution to this?
Mark Payne
on Jan 23, 2014 at 12:30:24 am
Hi Doug.
Thanks a million.
QuickTime 7 was the answer.
It did a great job.
Can't believe FCP, being an apple product, was causing such a problem. Many thanks for the advice!
I will deliver tomorrow and if lucky we might apparently make I-tunes for valentines day!
Mark
Doug Johnson
on Jan 23, 2014 at 12:37:32 am
I was having the same problem with the same codecs. Just like Nick advised, QT worked for you and Compressor worked for me.
Glad you sorted it out!
Mark Payne
on Jan 23, 2014 at 1:12:40 am
Hi Doug,
Seems like I had my Nicks and Dougs mixed up.
Glad you sorted it too. I was not having a good time...
All's well now.
Mark
