Render Clips & Quicktime
john oshea
on Jan 14, 2014 at 6:41:20 pm
Hi, can anyone explain to me that when i want to play a rendered A/V clip from Final Cut Pro 6/7 in Quick Time the audio is disabled (Greyed out) It plays the capture scratch & master clip fine but when i play the Render Files in Quicktime the audio is disabled for some reason
Shane Ross
Re: Render Clips & Quicktime
on Jan 14, 2014 at 7:22:53 pm
Audio and video render files are separate. Mainly because you might need to render only picture, so only picture is rendered, thus the render file has no audio.
Shane
Little Frog Post
