ProRes 422 Files Blurry in FCP7 Canvas?
Maya Rudolph
on Jan 13, 2014 at 5:53:05 pm
Hi all,
I am using FCP7 to edit ProRes 422 files. The files look great in the viewer, but appear pixelated and blurry in the canvas. I did an export test and they also export in the same blurry way.
The clips are 1910x1080 ProRes 422s converted from MTS files using Anusoft Video Converter.
I believe the issue is that the 422s are too large for the FCP timeline/canvas, but I'm not sure how to compress them without losing quality. Any advice will be highly appreciated!
Shane Ross
Re: ProRes 422 Files Blurry in FCP7 Canvas?
on Jan 13, 2014 at 6:35:28 pm
What are your sequence settings?
[Maya Rudolph] "The clips are 1910x1080 ProRes 422s converted from MTS files using Anusoft Video Converter."
1920x1080 I hope. From what source?
[Maya Rudolph] "I believe the issue is that the 422s are too large for the FCP timeline/canvas"
Hardly. FCP is designed to work with full res, 1920x1080 ProRes 422, HQ or even 4444 files. I suspect your sequence settings are some other, lower quality setting, like DV/NTSC.
Shane
Little Frog Post
Maya Rudolph
on Jan 16, 2014 at 4:21:42 am
Thanks for your help.
Yes, they're 1920x1080, converted from MTS files from a Lumix GH2.
What should I try resetting the settings to?
Shane Ross
on Jan 16, 2014 at 5:42:39 pm
They need to match your clip. If you drop a clip into a blank sequence, FCP asks if you want the settings to match. Click YES.
Shane
Little Frog Post
