External Program Monitor FCPX
Patrick Morrow
on Jan 7, 2014 at 4:50:02 am
Hello,
Can someone tell me what Black Magic product at the cheapest price, that can provide me with a feed from a laptop to an external monitor. I am looking for full program out.
Thanks!!!
Patrick Morrow
Shane Ross
Re: External Program Monitor FCPX
on Jan 7, 2014 at 5:05:34 am
Decklink Ultrastudio Mini Monitor. $140.
http://www.blackmagicdesign.com/products/ultrastudiothunderbolt
Requires Thunderbolt
Shane
Little Frog Post
Patrick Morrow
on Jan 7, 2014 at 6:02:59 pm
Will that work with a Mac Book Pro? Can I install it myself?
Patrick
Shane Ross
on Jan 7, 2014 at 7:22:46 pm
If your laptop has THUNDERBOLT, then you simply connect a Thunderbolt cable to that box, and then the box to your HDTV. You will need to install the drivers for it. Those are found on the decklink.com site.
Shane
Little Frog Post
Patrick Morrow
on Jan 8, 2014 at 2:28:54 pm
Hi Shane,
You describe it as a box and it looks like a plug in board. Is this something that is external or internal?
Thanks so much!
Shane Ross
on Jan 8, 2014 at 4:06:05 pm
Click on the link again. Nothing on that link is a board...they are all external boxes. The one I mention, the cheapest...Mini Monitor...is a small box. Size of a deck of cards.
Shane
Little Frog Post
Colin McQuillan
on Jan 10, 2014 at 5:48:10 am
The Mini Monitor Shane suggests is a great affordable output device for monitoring. I do a lot of cutting while on the road and use one to tap into hotel TV sets or my SmallHD monitor that I travel with.
One thing to keep in mind when using one of these output devices with FCPX is to set your viewer to "Better Quality" instead of "Better Performance" as you will not be able to see any fields/interlacing issues and such even on the external monitor. (When set to better performance FCPX only outputs at a lower resolution, even to the external display which can mask issues.)
Colin McQuillan
Vancouver, B.C.
