format/size in sequence question re: red giant instant hd
Max Ferver
on Jan 4, 2014 at 7:16:30 pm
i am trying to use red giant's instant hd in final cut and when i put my sd clip into a sequence set for prores (1080) it appears to already be the same size as the 1080 hd clips in the sequence when playing back. when i use the instant hd it makes the clip ridiculously huge. i am not sure why final cut is doing this, in my experience if you put something in a sequence that is a smaller size than what the sequence is set to it will appear smaller but for some reason this time it isn't doing it. any help would be appreciated!
Shane Ross
Re: format/size in sequence question re: red giant instant hd
on Jan 5, 2014 at 1:45:52 am
Open the timeline clip in the Viewer. What does it say for SCALE?
Shane
Little Frog Post
Max Ferver
on Jan 5, 2014 at 5:17:56 pm
Aha! That was it. I knew it must be something simple that I was overlooking. Thanks for the help!
