FCP 7 - Issues with Image increasing in lightness.
Patrick Jones
on Dec 14, 2013 at 12:18:55 am
Working with Sony AVCHD converted to quicktime using using Media Converter. Shot in 1080P/24P and 1 clip in 1080P/60P (for a freeze frame in the middle of the clip). Sequence Settings Screen Shot and Attached here.
I add a cross dissolve and the gets in brighter until the cross dissolve is done, then it goes back to normal color. Time ramping a clip changes the brightness of the clip as well. Selecting the frame #, take a freeze frame and putting in-between two clips shows the freeze frame to also be brighter.
Any help would be appreciated.
thanks so much
FCS 3 - MBP 2.93ghz 4gb RAM, 300gb 7200 Internal HDD, iStarUSA Dual Dock with (10) 1TB 3.5 Seagate Barracuda drives, and a couple 250's Maxtors, and Seagates.
