FCP 7 Share Failure for bluray file
Evan Smith
on Dec 12, 2013 at 5:49:15 pm
I have been trying to share a bluray DMG for a while now and it keeps failing. I have done this dozens of times with this same project file (using the right click, "share" procedure) but all of a sudden, it's stopped working. The current error says "Share Failure 2X QuickTime Error: 0"
This message is not always the same. I've also seen "3X Service Down".
Has anyone encountered this before?
John Fishback
Re: FCP 7 Share Failure for bluray file
on Dec 12, 2013 at 10:41:20 pm
I've not seen that error, but when odd things happen with FCP I trash prefs, run Disk Warrior and then repair permissions.
John
MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.8.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
FCP-X 10.0.9, Motion 5.0.7, Compressor 4.0.7
Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
