Render and Export Settings for Large-Form Exports
Baird Reese
on Dec 11, 2013 at 3:11:00 pm
Working on a 2 x 2.93 GHz 6-Core Intel Xeon Mac Pro with 24 GB RAM -- for Final Cut 7.
I have a feature I'm outputting and was curious if there is anything I'm missing to optimize my output time.
Footage: Pro Res 4444
TRT: 85 mins.
Sequence is defaulted at 8-bit YUV. I have in-to-out light green Preview bars. I go to output and get the Error, so I go to render, 2 hours. Crap. I change the render to RGB. Light green bars gone. Strange because I thought Pro Res 4444 was YUV since it comes out of the camera (ALEXA) with a Rec709 color space.
Okay whatever. I go to export. Straight Quicktime Conversion. 2 hours.
Does this sound right?
After this I need to compress it down to an H.264. Is there a better way to do this instead of outputting a master and then bringing that into compressor?
I tried going straight to Compressor last night but after 11 hours it was still chewing on getting this fat bastard into an H.264.
Thoughts welcome.
Thanks.
Nick Meyers
Re: Render and Export Settings for Large-Form Exports
on Dec 11, 2013 at 3:57:04 pm
"Footage: Pro Res 4444
TRT: 85 mins.
I go to export. Straight Quicktime Conversion. 2 hours."
assuming this is 1920x1080 @24fps
that's a 160G file you are creating there, so yeah it doesn't sound too far off
"After this I need to compress it down to an H.264. Is there a better way"
yes, export as a reference file, non self contained.
THEN run it though Compressor.
nick
Shane Ross
on Dec 11, 2013 at 5:23:41 pm
DO NOT do Quicktime CONVERSION...that's recompressing the file. Either QT Movie, self contained (for a full res version of the show, in a single file)...to archive and use to convert to H.264...or Reference movie to use to convert.
Shane
Little Frog Post
