Basic audio sweetening in FCP 7
xavier pilsudksi
on Dec 8, 2013 at 10:43:50 pm
I am working on a project:
:45 spots, talking heads,
very good recorded sound/dial
a couple woosh sfx
ambiance music track I added in BG
I don't have the budget to send to a pro audio guy so I am hoping to do my own audio sweetening.
So far I applied the normalization on the clips... and made sure the overall level of the spot is around -12db.
How do I create this rich sound you get when a spot comes back from mixing?
Thx
John Fishback
Re: Basic audio sweetening in FCP 7
on Dec 9, 2013 at 5:15:10 pm
There are many ways an audio pro enhances a track. Basic tools are EQ and compression. although, there are many more. There's no preset formula. Google for tutorials on mixing. You will find good info.
John
MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.8.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
FCP-X 10.0.9, Motion 5.0.7, Compressor 4.0.7
Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
xavier pilsudksi
on Dec 11, 2013 at 2:07:06 am
googled .... nothing really serious / interesting comes up as far as sweetening.
"mixing" is getting the levels correct but I want to sweetened so it all sounds loud/rich w/o spiking
Tom Matthies
on Dec 11, 2013 at 6:56:31 pm
Try the compressor/limiter filter and play with the settings until you get the result you're looking for.
E=MC2+/-2db
xavier pilsudksi
on Dec 11, 2013 at 7:00:24 pm
thx for the tip.
Been doing that and quite happy with the results actually
Sascha Engel
on Dec 18, 2013 at 6:24:29 am
If you know how to work with Soundtrack Pro, which allows you to use VST Plugs,
Then get Ozone and WAVE, with this you can do a great audio finalisation.
Special the compressors and limiters of WAVE are incredible.
Greetings,
Sascha Engel
TIME BANDITZ Productions
http://www.youtube.com/taikang
xavier pilsudksi
on Dec 18, 2013 at 5:49:16 pm
thx, I'll check it out
