Final Cut X and SD cards
Bryce Douglass
on Dec 7, 2013 at 2:29:06 pm
Is it possible to store events and projects on an SD card and use Final Cut X? I'm asking because I have two 2TB drives already using other stuff and my time machine backup takes forever to process cause I'm constantly using media. I'm thinking if I could store the Final Cut X projects and events on one SD card and the files on another I could use Final Cut that way and it would save space and time on my time machine backup.
John Fishback
Re: Final Cut X and SD cards
on Dec 8, 2013 at 4:24:16 am
It should work, although, the speed of the SD card will matter. If you have a couple of cards try it out.
John
MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.8.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
FCP-X 10.0.9, Motion 5.0.7, Compressor 4.0.7
Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
Sascha Engel
on Dec 18, 2013 at 6:28:17 am
If you those files are important, make sure you have really good quality SD cards.
I did experience in the past sometimes issues with cheaper models, such as Transcend Cards.
Greetings,
Sascha Engel
TIME BANDITZ Productions
http://www.youtube.com/taikang
