FCP 7.03 start-up issue
Michael Lang
on Dec 5, 2013 at 8:19:43 pm
Out of the blue, my FCP is acting up. It will open only after the preferences are trashed. I thought you only had to do this once, but I have to do every time.
John Fishback
Re: FCP 7.03 start-up issue
on Dec 5, 2013 at 8:41:49 pm
You should also Repair Disk Permissions after trashing. However, when FCP goes crazy, I trash prefs, then run Disk Warrior, and finally, Repair Permissions. This has saved my bacon countless times over the years.
John
MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.8.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
FCP-X 10.0.9, Motion 5.0.7, Compressor 4.0.7
Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
Rainer Wirth
on Dec 6, 2013 at 1:52:17 pm
We use digital rebellion for this issue - worth every cent
cheers
rainer
factstory
Rainer Wirth
phone_0049-177-2156086
Mac pro 8core
Adobe,FCP,Avid
several raid systems
Michael Lang
on Dec 6, 2013 at 9:13:19 pm
Thank you Rainer, the Digital Rebellion download did the the trick.
