CanonE1 plug-in crashes Log and Transfer FCP7
Edward Harby
on Dec 4, 2013 at 2:08:03 am
Hey guys, I've been log and transferring footage on FCP 7 and it's been crashing every 20-30 clips or so. It's only been crashing through log and transfer, and the problem report blames the CanonE1 plug-in (although I have my reasons that-that is not the real reason). I've reinstalled final cut, then reinstalled the plugin several times. I've repaired disk, repaired permissions, restarting the pram, etc.
I've used plug-in manager and disabled all plugins. I've deleted all the quicktime components that have nothing to do with apple... I've updated final cut. Trashed my preferences repeatedly. ETC
In the report it also mentions...
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x000000003e816000
Here's the report from Crash analyzer ... (I apologize if it's too long, I'm not trying to just dump this info on you guys, I spent 2 days trying to figure this out. I just want it run while I sleep... It's a lot of footage)
0 libsystem_platform.dylib 0x96cee3a1 _platform_memmove$VARIANT$sse42 + 145
1 com.apple.QuickTimeComponents.component 0x98b83455 0x988e0000 + 2765909
2 com.apple.QuickTimeComponents.component 0x98b864f1 0x988e0000 + 2778353
3 com.apple.CoreServices.CarbonCore 0x910b46e8 callComponentStorage_4444444444444 + 141
4 com.apple.CoreServices.CarbonCore 0x910a3d47 CallComponentFunctionCommonWithStorage(char**, ComponentParameters*, long (*)(), unsigned long) + 45
5 com.apple.CoreServices.CarbonCore 0x910a3d87 CallComponentFunctionWithStorageProcInfo + 30
6 com.apple.QuickTimeComponents.component 0x98b803f6 STMediaComponentDispatch + 77
7 com.apple.CoreServices.CarbonCore 0x91015ee5 CallComponent + 166
8 com.apple.CoreServices.CarbonCore 0x91015f5c DelegateComponentCall + 24
9 com.apple.QuickTimeComponents.component 0x98b5dc52 Video2ComponentDispatch + 78
10 com.apple.CoreServices.CarbonCore 0x91015ee5 CallComponent + 166
11 com.apple.CoreServices.CarbonCore 0x91015f3f CallComponentDispatch + 29
12 com.apple.QuickTime 0x917f4096 MediaGetSampleB + 109
13 com.apple.QuickTime 0x916a5ddd GetMediaSample2_priv + 133
14 com.apple.QuickTime 0x917ebed2 GetMediaSample2 + 113
15 com.canon.CanonE1 0x1979e61c -[CanonE1_IngestObject(PrivateUtility) CreateDecodeFrame:atTime:size:duration:] + 349
16 com.canon.CanonE1 0x1979da5a -[CanonE1_IngestObject getNextMedia:inRefCon:] + 1117
17 com.apple.proapps.MIO 0x0107d2cb TundraPluginCallbackProc + 355
18 com.apple.TundraComponent 0x5956f3f7 0x59500000 + 455671
19 com.apple.TundraComponent 0x5950bc69 0x59500000 + 48233
20 com.apple.TundraComponent 0x5954085c 0x59500000 + 264284
21 com.apple.TundraComponent 0x595797c1 0x59500000 + 497601
22 com.apple.TundraComponent 0x5958e2bb 0x59500000 + 582331
23 com.apple.TundraComponent 0x5950bc69 0x59500000 + 48233
24 com.apple.TundraComponent 0x5954085c 0x59500000 + 264284
25 com.apple.TundraComponent 0x595797c1 0x59500000 + 497601
26 com.apple.TundraComponent 0x5959062b 0x59500000 + 591403
27 com.apple.TundraComponent 0x5950bc69 0x59500000 + 48233
28 com.apple.TundraComponent 0x5954085c 0x59500000 + 264284
29 com.apple.TundraComponent 0x595797c1 0x59500000 + 497601
30 com.apple.TundraComponent 0x5959062b 0x59500000 + 591403
31 com.apple.TundraComponent 0x5950bc69 0x59500000 + 48233
32 com.apple.TundraComponent 0x5954085c 0x59500000 + 264284
33 com.apple.TundraComponent 0x595797c1 0x59500000 + 497601
34 com.apple.TundraComponent 0x5959062b 0x59500000 + 591403
35 com.apple.TundraComponent 0x5950bc69 0x59500000 + 48233
36 com.apple.TundraComponent 0x5954085c 0x59500000 + 264284
37 com.apple.TundraComponent 0x595797c1 0x59500000 + 497601
38 com.apple.TundraComponent 0x5959ccbe 0x59500000 + 642238
39 com.apple.TundraComponent 0x5950bc69 0x59500000 + 48233
40 com.apple.TundraComponent 0x5959d319 0x59500000 + 643865
41 com.apple.TundraComponent 0x5959d368 0x59500000 + 643944
42 com.apple.TundraComponent 0x595b24b1 0x59500000 + 730289
43 com.apple.CoreServices.CarbonCore 0x91015ee5 CallComponent + 166
44 com.apple.CoreServices.CarbonCore 0x91015f3f CallComponentDispatch + 29
45 com.apple.CoreMediaIOServicesPrivate 0x0111f8d7 TundraOutputUnitComponentCallRender + 49
46 com.apple.CoreMediaIOServicesPrivate 0x0111f6d6 TundraOutputUnitCallRender + 106
47 com.apple.CoreMediaIOServicesPrivate 0x0110fe94 MIOGraph::PullOutputUnits(bool, bool&, bool&, bool&) + 262
48 com.apple.CoreMediaIOServicesPrivate 0x0110cba9 MIOGraph::PullAndProcessThreadEntry() + 457
49 com.apple.CoreMediaIOServicesPrivate 0x0110c8f3 MIOGraph::_PullAndProcessThread(MIOThreadPriv*) + 533
50 com.apple.CoreMediaIOServicesPrivate 0x011129bc start_thread + 54
51 libsystem_pthread.dylib 0x930c95fb _pthread_body + 144
52 libsystem_pthread.dylib 0x930c9485 _pthread_start + 130
53 libsystem_pthread.dylib 0x930cecf2 thread_start + 34
Shane Ross
Re: CanonE1 plug-in crashes Log and Transfer FCP7
on Dec 4, 2013 at 7:15:50 am
What OS are you running?
Shane
Little Frog Post
Edward Harby
on Dec 4, 2013 at 7:41:07 am
Maverick. 10.9
By the way, I'm using your tutorial for log and transfer. Thanks a bunch for that.
Shane Ross
on Dec 4, 2013 at 7:54:32 am
The EOS Log and Transfer plugin isn't compatible with Mavericks. It was written for 10.8...and FCP 7 was discontinued 2.5 years ago, and the plugin for it as well. The plugin hasn't been updated for Mavericks, nor will it be. That's the problem with new OS and old software...compatibility issues.
Shane
Little Frog Post
