codec not found
roland salem
codec not found
on Dec 2, 2013 at 11:40:09 am
final cut 7 is showing me this message when i launch it "codec not found.you ma using a compression type without the correspondant hardware card"
when i open the project i cannot see the preview ,i can see only black and i can hear the audio
can someone help
thanks
Joseph Owens
Re: codec not found
on Dec 3, 2013 at 6:58:32 pm
What codec is your sequence base?
What codec is your media?
Do you have any illegal characters in the media names?
What is the resolution of your media?
Do you have any media over 4K in dimension?
jPo
"I always pass on free advice -- its never of any use to me" Oscar Wilde.
roland salem
Re: codec not found
on Dec 5, 2013 at 12:51:14 pm
hello
the original media is Mpeg4 ,i logged and transfered to apple pro res 422
the sequence settings are: Xdcam ex 1080p 25
the resolution is full HD
no illegal characters in the media and no footage over 4k dimensions
Ps: earlier i updated the Mac pro in the software update and some new codecs are downloaded.could that have done a conflict with the project? because im not facing this prob with only this project but also with another project that is shot in dufferent format and different codecs, plus that I opened both the projects on another Mac and they worked normally.
if its a software update issue, what should i do?
thanks
