FCP7/Blackmagic MiniMonitor/no playback on external monitor
Lisha Rigney
on Nov 26, 2013 at 6:14:23 pm
Hello to all,
Not sure what I'm doing wrong but video will not playback on my Boland external monitor. A frame will show on the monitor when parked on the timeline but video won't play through when playing the timeline. Can anyone shed light on where my settings are incorrect?
Thanks so much,
Lisha
iMac 3.4 Ghz
FCP7.0.3
OS 10.8.5
Blackmagic Mini Monitor
Shane Ross
Re: FCP7/Blackmagic MiniMonitor/no playback on external monitor
on Nov 26, 2013 at 6:35:07 pm
In the EXTERNAL VIDEO menu...just above the VIDEO PLAYBACK...make sure it is set to ALL FRAMES
Shane
Little Frog Post
Lisha Rigney
on Nov 26, 2013 at 6:40:43 pm
Hi Shane,
Yes it is. UGH!!!! What to do? :-)
Shane Ross
on Nov 26, 2013 at 6:42:29 pm
IN the Blackmagic preference pane, in SYSTEM PREFERENCES...in the SYSTEM PROCESSING tab...are ALL OUTPUTS active?
Shane
Little Frog Post
Lisha Rigney
on Nov 26, 2013 at 6:45:12 pm
Yes.
Lisha Rigney
on Nov 26, 2013 at 6:58:31 pm
Yes.
Also, in Final Cut Pro I can click on "Show Current" and the current frame will show on my external monitor.
Shane Ross
on Nov 26, 2013 at 7:18:06 pm
Uninstall and reinstall the drivers. Get the LATEST drivers, and install those.
Shane
Little Frog Post
Massimo Alberto Croce
on Nov 26, 2013 at 7:58:57 pm
what about the canvas in fcp? had the same behaviour? if so,one reason could be that the canvas is in Wireframe mode.
Video Editor, Colorist, Pro Tools Editor
massimoalberto.croce@gmail.com
Lisha Rigney
on Nov 26, 2013 at 8:17:18 pm
Footage plays in the canvas. When I stop playing the timeline the frame I stopped on shows on my external monitor.
Lisha Rigney
on Nov 26, 2013 at 8:15:05 pm
Uninstalled and reinstalled the latest driver from the website. Still able to see the frame I'm parked on in the timeline on my external monitor but footage in the timeline will not play in the external monitor.
Gary Milligan
on Nov 26, 2013 at 8:03:17 pm
I don't use either FCP or Blackmagic hardware so this is just a guess - according to your screenshots your source is 8 Bit and you've selected 10 Bit in the list. Have you tried the 8 Bit setting?
HTH
Gary
Lisha Rigney
on Nov 26, 2013 at 8:19:23 pm
Thank you for bringing that to my attention Gary. Tried it and still no playback on my external monitor.
Lisha Rigney
on Nov 26, 2013 at 8:51:14 pm
Thank you everyone! Honestly not sure if it was uninstalling/reinstalling the drivers or switching from 10-bit to 8-bit but after THREE restarts the picture is playing in my external monitor.
Thanks so much!!!!
Lisha
