Audio Slowing Down in FCP7
Nathan Matta
on Nov 22, 2013 at 9:02:59 pm
I've searched through this forum before and I cannot find a fix for this issue. Most of the time FCP 7 works fine. However, recently projects keep playing back with half speed audio and bringing up a rendering error, and the messed up audio is still there when I export. I've deleted my user preferences and have even uninstalled and reinstalled FCP 7. Nothing works completely, and I end up running into the same issue.
Thanks for any help!
Nathan Matta
Re: Audio Slowing Down in FCP7
on Nov 22, 2013 at 9:29:04 pm
It keeps bringing up the Dropped Frames Warning when I try playing anything back.
Sometimes the audio is slow, sometimes it's gone. Other times, it's fine in one ear and slow in the other ear. I am completely at a loss!
Shane Ross
on Nov 22, 2013 at 11:54:40 pm
What is the format of the footage you are editing with? What are your sequence settings?
Shane
Little Frog Post
Nathan Matta
on Nov 25, 2013 at 1:46:42 pm
The sequence settings are as follows.
Video:
XDCAM HD 1080p24 (35 mb/s VBR)
Audio:
48 kHz 16-bit
Nathan Matta
on Nov 25, 2013 at 2:26:04 pm
I feel sheepish! I just noticed that the WAV music that I am using is 44.1 mHz and the sequence is at 48 mHz. When I changed the sequence settings to 44.1, things started working fine. I hope that was the issue!
Thanks for your help.
