New Macbook Pro and FCP 7
Elizabeth Johnson
on Nov 18, 2013 at 12:34:38 am
I just received my new Macbook Pro Retina in the mail (OS X 9), and transferred all the data from my hard drive to it.
I tried to copy over FCP 7 from my applications folder on my old Mac external hard drive to my new Macbook, but it seems an application like FCP can't just be copied over like this.
If that is the case, does anyone have any advice on what to do? I am in the midst of editing a big project on FCP 7 for the past year, and want to continue. Any thoughts would be greatly appreciated.
Thanks.
Life is worth living.
Shane Ross
Re: New Macbook Pro and FCP 7
on Nov 18, 2013 at 2:54:38 am
Install from the original discs. Or did you lose those in a move?
Shane
Little Frog Post
Elizabeth Johnson
on Nov 18, 2013 at 4:43:40 am
Thanks for your response, Shane. I no longer have the discs her with me- was several years and two international moves ago. Also, the new macbook doesn't have a cd/dvd drive anymore.
I'm also wondering, though, if anyone has successfully used fcp 7 on the brand new macbook pro, as I have been hearing mixed reviews?
Steve Eisen
on Nov 18, 2013 at 5:06:04 am
In order for FCP to work correctly, you will need the original install discs. A finder copy will not install all the files needed.
1. You can take your old hard drive and use that as a boot disc.
2. You can clone your old hard drive and use it as a boot disc.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Creative Pro Users Group
Shane Ross
on Nov 18, 2013 at 5:40:25 am
Apple sells external DVD drives. I have one myself.
And sorry, but if you want FCP to work properly, you need to install it from those discs. Migrating simply will not work. Always hold onto your software installers.
Shane
Little Frog Post
Nick Meyers
on Nov 18, 2013 at 3:21:41 pm
did you simply copy things manually, or did you use the migration assistant?
that has worked for me in the past
(but i am going back to about 2008 / 2009)
nick
Nikolas Bäurle
on Nov 18, 2013 at 6:58:41 pm
I just used FCP7 on a Retina MacBookPro. Other that a few minor beach ballers during editing everything worked well. The funny things was that I didn't have one single crash, and this was at the place I always have FCP7 crash issues and corrupt projects when using their 12-Core Mac Pros, connected to the same server.
William Carr
on Nov 19, 2013 at 10:19:40 pm
I used Migration Assistant to transfer my entire 2010 Macbook Pro into my brand new Retina Macbook Pro, including FCP 7 which works fine and renders faster in the new machine. Other than reinstalling from the app disks, Migration Assistant may be the only practical method.
