Cannot add BPAV folders into XDCAM Transfer for conversion to FCP7.
Cullen Smithson
on Nov 5, 2013 at 7:15:28 pm
I'm using 2.5.1 XDCAM Transfer but when I'm trying to "Add Source" folders the BPAV folders (on an external HD) are greyed out when trying to add them.
Eventually I want to import this footage to FCP 7.
Running OS X 10.6.8
Any suggestions why I'm not able to add these folders?
Rafael Amador
Re: Cannot add BPAV folders into XDCAM Transfer for conversion to FCP7.
on Nov 5, 2013 at 10:34:01 pm
Is the BPAV folder inside another folder?
If not, open a new folder, name it and put the BPAV folder inside.
In XDCAM Transfer you have to add the new folder.
You have to do the same to each BPAV folder.
rafael
Cullen Smithson
on Nov 5, 2013 at 10:43:22 pm
I needed to update the XDCAM Transfer tool. I used this...2.13 is available under 'legacy applications' at http://www.sony.com/xdcam-downloads
