Multicam not working with Mavericks?
Steve Stern
on Nov 2, 2013 at 11:01:13 pm
Ever since I upgraded to Mavericks, FCP X 10.0.9 is not creating multicam clips. If I select 2 clips to make into a multicam, it simply concatenates the clips, even when I use first marker to synchronize. Any advice?
Shane Ross
Re: Multicam not working with Mavericks?
on Nov 2, 2013 at 11:21:45 pm
Only snarky advice:
Go back to an OS that works with FCP 7. Mavericks wasn't written with support for FCP in mind. If you rely on a machine to make money, don't upgrade.
Shane
Little Frog Post
Steve Stern
on Nov 3, 2013 at 2:18:02 am
Found a fix. You need to name the angles and it seems to work better. This video is where I found it.
Shane Ross
on Nov 3, 2013 at 6:24:33 am
I didn't notice you said FCX...sorry.
Shane
Little Frog Post
