FCP7 conversion to something that will work on PC
chris rust
on Nov 2, 2013 at 3:42:36 am
Hi All,
OK, I’ve been shooting HD and HDV for a long time – editing non-linear since the late 90’s, and I’ve always worked on Macs. I don’t know why, but export formats still mystify me – especially when (trying to) plan(ning) for use in PCs. Everything seems to continue to change from month to month, etc. I have a project shot on HDV, edited in FCP7 ( HDV native). My client wants me to output a version onto 16gb flash drives for playback on PC laptops. My initial output was to QT – giving me a .mov file. The first test on a PC the .mov would not play. Downloaded QT for Windows, tried again – no luck. Then I tried converting to Mp4. This test was interesting, because the vid played back, audio was good, but the aspect was wrong. The picture had been squeezed. Then I tried converting to .avi – still no luck.
What the hell am I doing wrong? Is Jobs haunting me from the grave? What do I have to do to complete my task successfully?
Please help!!!
Mahalo,
crusty50@gmail.com
Mark Suszko
Re: FCP7 conversion to something that will work on PC
on Nov 2, 2013 at 4:12:42 am
If you are talking about playing the file off of a thumb drive, if the files are high def, the drives may not have the transfer speed to play clean; are you having users drag the video to their desktops first? That way it plays off their hard drive instead.
When I make files to share to unknown places, i use h.264 and windows media. Usually one or the other will work. But again, playing anything larger than a 30-second clip direct off a thumb drive may not play clean.
Just my own opinion.
chris rust
on Dec 6, 2013 at 1:01:42 pm
Thanks for your suggestions. Here are my results… Yes I did consider that the flash drive transfer speeds would not be fast enough and did try dragging the vid to the desktop -- no difference.
You say you use H264 AND Windows Media. If you don't mind, please explain what you mean by that. I understand H264 is what I'm trying to get from Compressor. Windows Media? Are you talking about the player on the PC? or something else?
I have also tried creating different versions using the QT Conversion settings and came up with some really ugly looking video.
Going the h264 route: creates a file that is something on the order of 3X the size of the .mov (which was too big to begin with). Took forever -- became such a size that I couldn't get it onto a flash drive (11gb became 30+gb).
Now, if necessary, I'll take my machine to theirs and make a transfer via ethernet -- but that doesn't account for backup copies....
Second, I made an MPEG2 version and stored it on DVDs. They would not play on the PC either. This is the way I have delivered to non-broadcast clients for years and has always worked. I use the DVD MPEG2 Best Quality 90 minutes and AAC audio settings.
I looked at the flip4mac site and of course, the version I need is the most expensive. There must be some alternative to spending $180 to convert these files.
Again I thank you for your suggestions and taking the time to respond to my query.
Mark Suszko
on Dec 7, 2013 at 6:08:09 am
I meant .WMV format, using flip4mac, either exporting from the timeline directly, or from compressor. Other tools I use are FLCrunch and the ever-popular MPEG STREAMCLIP.
Rainer Wirth
on Nov 2, 2013 at 2:22:24 pm
It depends on the software on a windows based PC.
Nearly every PC has got a windows media player. Best format is WMV. If the PC has got a Quicktime player it will play quicktimes. The safest format is WMV 4:3 letterboxed. If the media player is an actual version it will also play H264(Mpeg4).
By the way, we do all transcodings with Episode,
cheers
Rainer
factstory
Rainer Wirth
phone_0049-177-2156086
Mac pro 8core
Adobe,FCP,Avid
several raid systems
Rafael Amador
on Nov 3, 2013 at 10:55:31 am
[chris rust] " I have a project shot on HDV, edited in FCP7 ( HDV native). My client wants me to output a version onto 16gb flash drives for playback on PC laptops. My initial output was to QT – giving me a .mov file. The first test on a PC the .mov would not play. "
SONY had the brilliant idea of making different the HDV codecs for the Mac and te PC.
So HDV files are not cross-platform.
[chris rust] "Then I tried converting to Mp4. This test was interesting, because the vid played back, audio was good, but the aspect was wrong. "
Your choice of MP4 was correct.
The distortion is a different issue.
I guess you shoot HDV 1080, which is 1440x1080 HD Pixels, but the standard for HD is 1920x1080 SQUARED PIXELS.
So when exporting, in the Geometry options, change to that specs; 1920x1080 Squared Pixels.
if there is not an option for pixels (QT Player), just forget about and export 1920x1080.
rafael
