FCP 7 and HDMI output
Michael Bigda
on Oct 31, 2013 at 1:51:22 pm
Quick question. Does FCP 7 work well with playing video with an HDMI output? What should my settings be to play it out of a HDMI output?
Rainer Wirth
Re: FCP 7 and HDMI output
on Oct 31, 2013 at 3:35:23 pm
What do you mean HDMI output - it depends on your monitoring system. We work with Aja kona LHI and 3G and the HDMI output is flawless. If you have got a HDMI output with your breakout box then it is fine.
cheers
Rainer
factstory
Rainer Wirth
phone_0049-177-2156086
Mac pro 8core
Adobe,FCP,Avid
several raid systems
Michael Bigda
on Oct 31, 2013 at 4:19:53 pm
I do have an hdmi on my breakout box. Right now I use a blackmagic setting to view on an external monitor. What setting should I use for the HDMI
Rainer Wirth
on Oct 31, 2013 at 4:49:28 pm
Hi Michael,
what breakout box do you use?
Settings depend on your FCP settings. If you use SD, you set your settings in SD with HDMI, if you use HD you use your timeline settings in HD, for example interlaced, progressive, etc. I would go for 8 bit, but this depends on your breakout box and your monitor.
cheers
Rainer
factstory
Rainer Wirth
Mac pro 8core
Adobe,FCP,Avid
Shane Ross
on Oct 31, 2013 at 5:16:23 pm
Same setting. Once you send it to the BMD box, all the outputs are active.
Shane
Little Frog Post
