Final Cut Studio
Rick Helderman
Final Cut Studio
on Oct 26, 2013 at 7:32:39 pm
Hey, I can't seem to get past square one. My hard disk went bad so I had it replaced now I can't log and transfer my video to final cut. I can see it and drag it to the queue and it says clips are queued but when I click on them in the status area it shows a stop sign with a exclamation point in it and it says there is no data. I had this same problem when I originally loaded final cut and it's driving me crazy. Oh yea and it also says that the queued clips are idle.
Shane Ross
Re: Final Cut Studio
on Oct 27, 2013 at 2:52:16 am
Did you install FCP from scratch?
Shane
Little Frog Post
John Street
on Oct 27, 2013 at 5:25:55 pm
I have run into this problem when the hard drive containing the raw footage is connected by USB ... the problem clears up as soon as I connect via Firewire ... not sure this will help, but that's one of the weird workarounds that has helped me ...
John Street
http://www.inpoint.tv
Mac OS 10.7.5, FCS 7.0.3, QT 7.6.6, Mac Pro 2x3GHz Quad-Core, 16GB Ram
