Plug-in to remove lines going up and down screen?
Alex Townley
on Oct 25, 2013 at 2:37:45 am
Hi guys,
I was wondering if anyone could give me any tips on how I can fix this footage recorded in a nightclub. There appear to be lines going up and down the screen throughout probably due to a lighting issue. I have tried flicker filter, de-interlace and shift fields filter without any luck..does anyone have any suggestions or is it unfixable?
N.B. The lines arent quite as visible as before due to video compression but can still be seen particularly on bottom left side.
Alex
nightclub_test
Shane Ross
Re: Plug-in to remove lines going up and down screen?
on Oct 25, 2013 at 5:15:15 am
Looks like the lighting in the club. I only see it on his shirt, and it's most likely some sort of spinning globe with light...normal.
Shane
Little Frog Post
Rainer Wirth
on Oct 25, 2013 at 12:00:51 pm
It looks all fine to me,
cheers
Rainer
factstory
Rainer Wirth
phone_0049-177-2156086
Mac pro 8core
Adobe,FCP,Avid
several raid systems
Mark Suszko
on Oct 25, 2013 at 2:01:27 pm
Back up a minute and tell us all about the settings used to shoot this and to edit it.
Tom Matthies
on Oct 25, 2013 at 5:51:17 pm
It could be consumer-level LED lighting? It's notorious for causing all kinds of problems with video cameras.
E=MC2+/-2db
Alex Townley
on Oct 26, 2013 at 9:13:23 pm
Apologies..I am going to upload a longer clip now which hopefully highlights the problem better. The video was shot on a Canon 7D - 1920x1080 (H264) which I then converted to Apple Pro-res LT.
Thank you for the responses so far!
nightclub_test2
