Will FCP 7 finally stop working - Mavericks
Neil Sadwelkar
on Oct 23, 2013 at 10:44:45 am
Anyone running FCP 7 on the new Mavericks OSX 10.9?
Will 10.9 be the OS that finally causes FCP 7 to stop working? Is it possible to install FCP 7 on a new Mavericks-installed Mac?
Neil Sadwelkar
neilsadwelkar.blogspot.com
twitter: fcpguru
FCP Editor, Edit systems consultant
Mumbai India
Steve Walker
Re: Will FCP 7 finally stop working - Mavericks
on Oct 23, 2013 at 11:39:12 am
Quick answer, for me on my 2009 Macbook Pro, so far so good. Posted a more lengthy summary just above yours.
Good luck.
s regian
on Oct 23, 2013 at 1:45:45 pm
Working for me so far... as expected. No problems to note.
Mark Suszko
on Oct 23, 2013 at 2:46:38 pm
What about the rest of the suite: DVDSP, Compressor, Motion?
s regian
on Oct 23, 2013 at 3:42:08 pm
Just opened STP, Compressor 4, DVDSP and Color. All opened although I didn't actually open any saved projects other than STP they all looked as though they would work fine.
Michael Rolt
on Oct 23, 2013 at 5:30:31 pm
Hi Steve,
Am in the same situation.. and my Expresscard is out of action. Could you possibly let me know where you got that driver? Can't seem to find that exact one.
Mike
Steve Walker
on Oct 23, 2013 at 6:42:05 pm
I got the driver here Mike;
http://www.siliconimage/support
from the product support drop down select
Sil3132...........
then after 1.7.5 and 1.2.5 failed I went for 1.2.3
Good luck
Steve Walker
BBC Senior Tech Op. Editor/Sound Mixer
FCP-Quantel-Avid
Michael Rolt
on Oct 24, 2013 at 11:53:10 am
Hi Steve,
Thanks so much for the speedy reply. Much much appreciated. I've installed the driver and, although I now have the card icon at the top right of my finder window and it says Silicon Image and Sil3132 etc when I click on it - they are greyed out. Did you uninstall or delete the previous Extension files etc before you installed the old driver? I'm worried I've messed around so much with drivers your solution won't work for me..?
Any ideas would be great. I am losing so much time here!
Steve Walker
on Oct 24, 2013 at 3:32:02 pm
Hi Michael,
I have a Lacie 2TB Drive and a Lacie SATA II ExpressCard 34. Not sure which driver I had before Maverick, which ever it was survived the update from Snow Leopard to Mountain Lion.
I checked out my drivers folder and in ;
System/Library/Extensions there are 2 files;
SiliconImage3132.kext
SiliconImage3132r5.kext
I also found the 'Incompatible Software' folder and in that was one of the files from above;
I didn't uninstall the previous drivers, and my exact process was to download and install;
sil3132.......1.7.5
sil3132.......1.2.5
then finally
sil3132.....1.2.3
then everything worked for me.
Hope that helps
Steve Walker
FCP-Quantel-Avid
