Second export through FCP and compressor
Andy Morin
on Oct 18, 2013 at 2:53:22 pm
So i just exported a couple of videos through compressor as h.264 files and the audio is kindve low. Each of these files took about 4 hours to compress. Is it ok to just reimport the h.264 footage into tcp again, raise the audio meters and export? and if so what compression settings are recommended the 2nd time
Rainer Wirth
Re: Second export through FCP and compressor
on Oct 18, 2013 at 2:58:28 pm
Hi Andy,
if you set your audio levels right in FCP let's say -6db, you audio is fine in Compressor. I would go over again.
cheers
Rainer
factstory
Rainer Wirth
phone_0049-177-2156086
Mac pro 8core
Adobe,FCP,Avid
several raid systems
Andy Morin
on Oct 18, 2013 at 3:04:29 pm
So i can send the newly compressed h.264 files back into FCP and send to compressor again? What settings would be o.k to use the second time without recompressing and keeping the quality?
Rainer Wirth
on Oct 18, 2013 at 4:28:35 pm
No, you have to send the original FCP files with the new sound settings to compressor.
cheers
Rainer
factstory
Rainer Wirth
Mac pro 8core
Adobe,FCP,Avid
Nick Meyers
on Oct 18, 2013 at 11:45:44 pm
you could try running through compressor again.
i think it's possible to raise the audio somehow, maybe with a filter
and set the video to bypass.
nick
Nick Meyers
on Oct 18, 2013 at 11:47:44 pm
or you could try something like your original idea:
inport into FCP, raise levels,
and export using same settings, so no re-compression on the video
not sure how that will work with H264, but worth a look, i guess
nick
Steve Eisen
on Oct 19, 2013 at 5:19:34 am
make sure your audio bit rate is at least 160 or higher.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Creative Pro Users Group
