Best HD format for submission to Withoutabox
Jan Laidlaw
on Oct 14, 2013 at 7:32:56 am
Are there any FCP7 users that have had success submitting an HD file to Withoutabox?
I am not that familiar with Compressor and the first setting I tried --H.264 for Apple TV-- played back fine but when it was uploaded to Withoutabox had that squished to 4x3 look.
I am fairly new to FCP and Compressor and haven't been able to figure out what I specifically need to do in FCP or in Compressor so that my HD file looks reasonable and is letterboxed, but not squished once uploaded.
This is what it says on the Withoutabox website:
We recommend the following settings to optimize video quality on the IMDb site for your Withoutabox upload:
* File size: Less than 2GB
* Frame: 480 px by 360 px at 30 frames per second
* Format: Flash Video (Codec: Sorenson or VP6 codec) or Quicktime
FLV videos using the H.263 video codec and the MP3 audio codec
MP4 videos using the H.264 video codec and the AAC audio codec
* We have had some trouble processing Apple QuickTime Pro files. Please convert this file type to an alternate format before attempting your upload.
* We do not currently support HD video. You will be able to upload an HD video, but the file will NOT be displayed in HD.
Can someone tell me what specific steps I can take in FCP or Compressor because I am at a loss. I tried converting from HD to a cropped version of SD and it looks awful. Letterboxing would be okay. But there must be a simple way to do this?
Rainer Wirth
Re: Best HD format for submission to Withoutabox
on Oct 14, 2013 at 12:37:15 pm
Hi Jan,
if the H264 for Apple TV plays fine then keep this codec in compressor. You just have to do a letterbox Format. Just make up a new sequence in 4x3 within FCP, throw the 16x9 Quicktime on the 4x3 sequence and its letterboxed. Export via compressor H264 for Aplle TV.
cheers
Rainer
factstory
Rainer Wirth
phone_0049-177-2156086
Mac pro 8core
Adobe,FCP,Avid
several raid systems
Jan Laidlaw
on Oct 14, 2013 at 4:21:55 pm
Thanks Rainer
Sorry if this is a stupid question but I've just started using FCP a couple of weeks ago. How would I make up a new sequence in 4x3? Would I change the sequence preset? And if so to what?
What are the steps to adding 16x9 Quicktime? i.e. is this a filter, a sequence preset...?
Just to clarify, the H264 for Apple TV played fine when I viewed it on my computer but *not* when I uploaded it to Withoutabox. So I'm not sure it's the best setting in Compressor for this.
File size is also an issue, it takes forever to upload, but also because it's a screener I want the quality to look reasonable.
Rainer Wirth
on Oct 14, 2013 at 6:16:47 pm
Hi Jan,
if you make up a sequence in FCP in 4x3 and then throw a 16/9 QT movie on it it goes letterboxed automatically. The sequence then is 4x3. If you send it to compressor it is handled as a 4X3 movie. Okay, back to the codec for your withoutabox.
It says exactly what you have to deliver. I would deliver a FLV, but you need a payed plugin programme for it. So this is your codec with compressor:
You can define your own specs in compressor.
This is your frame rate and ratio:
* Frame: 480 px by 360 px at 30 frames per second.
So you create a QT movie from FCP (4x3 QT movie) This movie you can compress via compressor within your specs.
cheers
Rainer
factstory
Rainer Wirth
Mac pro 8core
Adobe,FCP,Avid
Jan Laidlaw
on Oct 15, 2013 at 5:37:37 am
Well this is what I ended up doing, and it looked reasonable enough once uploaded:
Export using quicktime conversion, click options.
Video Settings:
Compression: H.264
Quality: High
Frame reordering: yes
Enoding mode: multi-pass
Dimensions: 720x480 (640x480)
Scale: Letterbox
Audio settings left as is.
And then I read your latest response - thanks for that.
Hope this will help someone else. Probably me when I go searching for it again in the future. :)
Noam Osband
on Nov 6, 2013 at 1:12:01 am
Two questions:
1 - My film is 24fps. It won't get messed up if I compress it to 30fps?
2 - WMy original footage is 1920x1080. Is there any advantage to follow what Jan did and compress it to a large pixel size rather than the 640x480?
The Withoutabox site is so poorly run so I wonder if maybe they just haven't updated their specs and i can actually upload something of a higher quality than what they say to do.
