canon xl1s & final cut pro 7.0.3
gary graham
on Oct 9, 2013 at 4:54:48 pm
can someone please help
im trying to log and capture video from my canon xl1s mini dv into final cut pro 7.0.3
i have the firewire800 - 9pin male to 4 pin male connected to the canon & my imac
yet FCP wont recognise the camera and imovie wont or quicktime ?
when i check apple website for compatability with canon xl1s it says its a firewire camera compatible with FCP
(Canon XL1S PAL Easy Setup:DV-PAL FireWire Basic)
http://support.apple.com/kb/HT4887
is there anything im doing wrong or need to download etc for FCP to recognise the camera.
thanks.
Bill Dewald
Re: canon xl1s & final cut pro 7.0.3
on Oct 9, 2013 at 10:30:21 pm
I remember FCP being super picky when it came to talking to Canon cameras via firewire.
Do what Dave said about your prefs, and also look at the firewire side of it:
* Make sure your cable is properly functioning - they can be fragile
* Make sure you are using a separate FW bus for the capture - no other FW devices (including drives) should be on the same bus.
* Have your camera connected and in VTR mode before you launch FCP. I believe the XL1s displays a "DV IN" icon in the viewfinder when it's communicating through the FW port.
Good luck!
gary graham
on Oct 15, 2013 at 6:08:00 pm
when im connected via firewire 800 playing in vcr mode i dont see the info you mentioned above ( I believe the XL1s displays a "DV IN" icon in the viewfinder when it's communicating through the FW port.)
i'm stumped regarding is it a software problem or a faulty firewire cable 3 days old.
gary graham
on Oct 15, 2013 at 6:12:07 pm
i'm also connected to mains supply while playing vcr through firewire i had also seen that suggested to connect camera to mains instead of battery power.
just putting as much info as possible on as i can to eliminate what i've already tried.
Bill Dewald
on Oct 15, 2013 at 6:15:15 pm
It's quite possible that you've got a bad firewire cable. They are pretty fragile, and the four-pin variety is pretty rare at this point.
Since you've tested a variety of applications and devices, the common thread is the cable. Try exchanging it.
Also, are there any other devices on your firewire bus? Take a look at About This Mac > More Info > Hardware > Firewire. The idea is that the camera should be the only device on the firewire bus.
Good luck!
