scale 4.3 to 16.9 final cut pro
gary graham
on Oct 8, 2013 at 4:46:57 am
help a newb
To cut a long story short does anyone have a solution/tutorial
on how to scale 90 mins video footage recorded in 4.3 and scale it all to 16.9
using final cut pro.
thanks in advance.
Shane Ross
Re: scale 4.3 to 16.9 final cut pro
on Oct 8, 2013 at 5:12:29 am
4:3 SD to 16:9 HD? Or 4:3 SD to 16:9 SD?
Shane
Little Frog Post
gary graham
on Oct 8, 2013 at 5:43:40 am
as long as i can get the footage into 16.9 i would be happy.
the footage i have was recorded in 4.3 SD on a canon xl1s video camera.
if i could scale it to 16.9 SD that would be ideal to tie in with other footage recorded in 16.9 SD on other cameras.
Shane Ross
on Oct 8, 2013 at 4:14:03 pm
Double click on a clip to load it into the Viewer. Click on the MOTION tab, increase the scale by 33% to make it fill the screen, then adjust the position so that you see the area of focus you want. Repeat for all the footage. OR, if you want the framing to be the same for all, once you adjust the first on, copy and then PASTE ATTRIBUTES to all the rest.
Then render.
Shane
Little Frog Post
