new Panasonic camera /FCP 7.0.3 will not convert
mike Downing
on Oct 7, 2013 at 9:23:56 pm
I have a new panasonic AGAC90 camcorder.
I have a IMAC intel core i7.
I have FCP 7.0.3 on this mac, all work was with mini dv tapes.
This version of FCP will not convert the file from this camcorder(AGAC 90).
any assistance on proper setting up FCP to ways of converting file so I can work with them.
Shane Ross
Re: new Panasonic camera /FCP 7.0.3 will not convert
on Oct 7, 2013 at 11:21:28 pm
Are you using LOG AND TRANSFER? Back up the full card and choose the root level of that backup? The proper workflow is here:
Shane
Little Frog Post
mike Downing
on Oct 8, 2013 at 3:13:28 pm
When I log and transfer to FCP, files or clips show up on screen but in media duration column it shows not time and when I drag clip down I get a "No Data" tag in clip.
This is the same whether I use card files or backup files on mac.
Shane Ross
on Oct 8, 2013 at 5:09:56 pm
Well, AVCHD is a very odd format as each camera maker does it's own "spin" on it. They all make slightly different versions of AVCHD...there is no "standard." Because of that, and because it's a new camera, and because the last update FCP 7 saw was over 3 years ago...it might not be able to handle it on it's own.
Your best bet is to get ClipWrap2 from Divergentmedia.com. It is constantly updated to work with all formats of AVCHD, and convert them to ProRes, or DNxHD or whatever your NLE works with. ProRes for FCP...
It works where the NLE's might fail
Shane
Little Frog Post
