MXF->ProRes from Canon XF-305, need to set different output directories, Log&Transfer can not do this
go kudr
on Oct 5, 2013 at 11:05:52 pm
Is there any anologues to Log&Transfer?
Thanks in advance!
Rafael Amador
Re: MXF->ProRes from Canon XF-305, need to set different output directories, Log&Transfer can not do this
on Oct 6, 2013 at 2:45:26 am
I think you have to install a Canon plugin.
May be this:
http://software.canon-europe.com/software/0040354.asp
There is a ton of info about the Canon workflow in FC.
Google.
rafael
go kudr
on Oct 6, 2013 at 7:39:45 am
Ofcourse, i have already installed this plug
It appears in Log&Transfer's codecs menu
But i need a L&T alternative, because i still cant set different output directories for different csrds.
go kudr
on Oct 6, 2013 at 7:53:15 am
Another problem is, that if the "filename"-folder contains more than one .MXF-file - only the first one is converted, but the others are NOT!
How do people manage lots of material? I gues not with the help of L&T.
go kudr
on Oct 6, 2013 at 4:13:46 pm
Sorry, this one is not a problem. L&T just merges them, if the files are more than one))
