Configuring Luma Warning
Tancredi Capucci
on Sep 30, 2013 at 6:17:02 pm
Hi all,
i've recently been working with a client that's asking me:
HD programs must not have luminance levels above 700 millivolts (mv) or below 0 mv.
The program’s color difference signals (R-Y, B-Y) must not rise above 700 mv or fall below 0 mv when measured with a 350 millivolt offset.
I'm pretty sure that the FCP warning for luma excess is under 700mv because some of the original footage goes in luma excess even before i start working on it, besides recent material i sent him was exceeding and i never had problems wilts few last programs (still exceeding) didn't pass QC, is there any configuration window that allows me to set different levels for luma excess?
Go Cows!
Samuel Enblom
Re: Configuring Luma Warning
on Oct 1, 2013 at 7:59:43 am
Just a quick info-question... Have you tried FCP's luma-safe tool? It is, as far as I know, always safe for broadcast.
Tancredi Capucci
on Oct 1, 2013 at 12:07:40 pm
Aparently its set to some other different configuration level and not 700 MV
Go Cows!
Tancredi Capucci
on Oct 1, 2013 at 1:41:25 pm
you mean the yellow triangle and the green circle right?
Go Cows!
Samuel Enblom
on Oct 1, 2013 at 2:50:25 pm
Actually I didn't mean the symbols that just warn you when you're off limits. There is an actual filter in FCP that makes sure you're broadcast-safe. (It might actually be called broadcast-safe filter). I'm a little rusty since I have made the jump to premiere.
I didnt fully watch this tutorial but the title sounded nice in regards to this question and to explain what I meant:
Also creative cow has its own explanation of broadcast colors:
I hope this can be of some sort of ease for you.
Tancredi Capucci
on Oct 1, 2013 at 6:01:59 pm
The fist video just did it for me, thanks alot man it really helped out!! :)
Go Cows!
Samuel Enblom
on Oct 2, 2013 at 8:33:54 am
I'm glad I could help!
