Setting up FCP 7.0 best OSX?
Michael Harrington
on Sep 28, 2013 at 4:44:58 pm
I've been out of the loop a few years and doing research on compatibility of FCP 7.0 with OS X Snow Leopard 10.6.
I have a 500GB partition to do a clean install, I have original disc for FCP Studio 3 7.0 and OS X 10.6 Snow Leopard. I need to know if I clean install the disc and do not do any upgrades will this combination work properly.
I'll open a project that was done within FCP 7 but most likely later than 7.0. and I'm working in ProRes. I also use Matrox MXO2 MAX and will download the appropriate firmware for that combination to view SDI signal to my Flanders Scientific LM-1760 for color correction.
If I need to update OSX or FCP 7 am I able to select which versions to work best.
MAC Pro System
MacPro4,1
2 x 2.66 Ghz Quad-Core Intel Xeon
12 GB 1066 MHz DDR3
ATI Radeon HD 4870
Thank you for any advice you have or pointing me to good reference material.
Michael Harrington
Mac Pro, Dual Quad-Core Intel Xeon 2.66 GHz, 12 GB, FCP7, Snow Leopard, ATI Radeon HD 4870, 30-inch Cine Display, 4 - 1TB internal, G Speed 6TB Raid 5, 1.25TB Esata, Numerous FW 800 external drives, Matrox MX02Max, FSI 17" Broadcast Monitor, Black Magic Mini Sync Generator, Mackie 1402 & Event 20/20 monitors.
Rafael Amador
Re: Setting up FCP 7.0 best OSX?
on Sep 29, 2013 at 4:10:44 am
I would recommend you to install Snow Leopard, then update the system (Software Update: MacOs 10.0.6).
Once you have the system installed, install FCS3 and run Software Update to get the last FC version (FC.7.03).
You also needs to install the last version of QT Player ( 7.6.6 ?).
rafael
Alexander Kallas
on Sep 29, 2013 at 10:45:19 am
Raf, I had problems with QT7 after up-grading Snow-Leopard.
Yet on my MBP going up to Mountain Lion 10.8 FCS3 runs perfectly.
Cheers
Alexander
