Two Frames Before Cut go Dark
Emma DeGraz
on Sep 19, 2013 at 10:07:39 pm
I just edited a sequence in FPC7, 1920x1080 ProRes 422HQ. When I export the timeline out (no conversion) and play the quicktime file, there are a couple of spots where the last two frames before a cut either go dark or light. I don't think I've ever seen this before, has anyone else?
Emma DeGraz
Re: Two Frames Before Cut go Dark
on Sep 19, 2013 at 10:18:42 pm
Just tested- this does not happen when I choose "recompress all frames" or when I export with matching settings using Compressor.
Dave LaRonde
on Sep 19, 2013 at 10:36:38 pm
There is footage in the edit timeline that doesn't match the edit timeline's codec. Make it all one kind -- ProRes 422 is the gold standard for FCP -- to eliminate the problem.
Dave LaRonde
Former Sr. Promotion Producer
Emma DeGraz
on Oct 7, 2013 at 7:12:12 pm
It was all ProRes 422. I ended up dumping all the render files in Render Manager and re-rendering. This seems to have solved it.
