Converting 29.97fps to 23.98fps.
Alyssa Grinberg
on Sep 17, 2013 at 2:23:08 pm
I need to convert about 15 short clips to 23.98fps, which were originally 29.97fps. I am working in fcp 7. I tried compressing the clips in media manager but received a message that says "Frame Rate Conflict Found. The frame rate of the preset chosen for recompression differs from items in your selection. The preset's frame rate will be ignored and the original rate of the items in your selection retained." Unless I am missing something, this defeats the purpose.
Then I tried to export as a quicktime movie and that seems to work. When I bring it back into FCP the clip itself plays smoothly. But when I drop it into my timeline (which is set at 23.98) then it is very jerky. HELP! Is there anyway to do this internally? And if not, anyone suggest a business that I can pay to convert this footage? I am outside of the US.
Creatively it could work just fine to have a different "look and feel" to these clips so any work arounds are appreciated too.
John Fishback
Re: Converting 29.97fps to 23.98fps.
on Sep 17, 2013 at 4:01:06 pm
Try your conversion in Compressor. Turn on Frame Controls and select the highest quality for retiming. This can take a while to render so test with a short clip-one with some motion so you can judge the judder.
John
MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.8.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
FCP-X 10.0.9, Motion 5.0.7, Compressor 4.0.7
Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
Rainer Wirth
on Sep 19, 2013 at 2:59:13 pm
I would use a hardware encoding.
cheers
Rainer
factstory
Rainer Wirth
phone_0049-177-2156086
Mac pro 8core
Adobe,FCP,Avid
several raid systems
Keith Slavin
on Sep 20, 2013 at 6:20:24 pm
Hi Alyssa,
If you still have problems converting your clips from 29.97p to 23.98p smoothly, please check out our media conversion services http://isovideo.com/services.php, based on the IABM/NAB Game-Changer Award-winning Viarte standards conversion/transcoding server. We recently used Viarte for footage conversion (59.94i to 23.98p) for Ron Howard's “Made in America” documentary, which was world premiered at the Toronto International Film Festival on September 7, 2013. Please see details from http://isovideo.com/press_915.php (or http://news.creativecow.net/story/872888). Also you may want to see a testimonial from Jerome Raim, who was the lead assistant editor of “MiA” at http://forums.creativecow.net/thread/240/761#765. If you are interested in trying out our service, you could send email to keith@isovideo.com. We could run a quick test and see if it works for you.
Best,
Keith
