Pixellated export
Ben Hartley
Pixellated export
on Sep 16, 2013 at 2:57:15 pm
I know this is a common problem on these forums but I cannot work out how to solve the problem. Below is what it should be and what it is exporting as. I have the sequence set to Pro Res lt as is the footage within.
If you click on the images you can see the difference more clearly.
If it looks good, look at it.
Ben Hartley
Re: Pixellated export
on Sep 16, 2013 at 3:23:38 pm
Also my sequence is at 1080 with 100% render quality and Square pixel aspect ratio.
Mark Suszko
on Sep 16, 2013 at 3:46:50 pm
Do you have FCP defaulting to scaling incoming graphics, or leaving them native rez?
Ben Hartley
on Sep 17, 2013 at 9:11:29 am
Where do i check if its scaling incoming graphics?
Dave LaRonde
on Sep 16, 2013 at 4:28:49 pm
If you exported an interlaced file, and you're looking at it in a viewer, that's what you should expect to see.
Dave LaRonde
Former Sr. Promotion Producer
Ben Hartley
on Sep 17, 2013 at 4:07:52 pm
The video I am viewing in FCP is not interlaced.
