1440 1920 Frame Size and the Blackmagic Cinema Camera
George Kalpa
on Sep 14, 2013 at 7:41:14 am
I've nearly finished editing a short film on FCP7 with footage from a Blackmagic cinema camera.
The footage has looked great in the Canvas window through the whole edit.
Ive only just created a new sequence and allowed Final cut to auto match the sequence to the clip settings.
My original sequence is 1440x1080 (HD 1440x1080. UPPER ODD), this new auto matched sequence is 1920x1080 (SQUARE/NONE).
The footage in the 1920x1080 sequence looks as right as it does in the 1440 sequence.
I've tried changing the settings from 1440 to 1920 and to square and get a squashy picture, I've also tried exporting an XML and loading it in a new sequence or project with no luck (I get the same 1440 aspect ratio)
Any ideas on how to change this without re-editing/inserting the whole lot?
Thanks to all the contributors for the wealth of knowledge on this forum.
George
George Kalpa
Re: 1440 1920 Frame Size and the Blackmagic Cinema Camera
on Sep 14, 2013 at 2:20:05 pm
Looks like the clips had distort in motion at 33%. Changing it to 0% did the trick.
Regards,
George
Rafael Amador
on Sep 15, 2013 at 2:22:38 am
Select all the stuff in the sequence (1920x1080), and left-click > Remove Attributes: Basic Motion + Distort.
rafael
