lighting issues as was rushed with set up and noise is visible: http://www.youtube.com/watch?v=73-S6IU0OQg&feature=youtu.be
Jay James
on Sep 11, 2013 at 11:34:08 am
Hello
shot the interview yesterday and was rushed with the setup used an LED that I attached to my camera for additional lighting - can't afford to lose this footage as won't be able to do this interview again- do you think I can get away with how it looks now or is it a write off or can anyone suggest a way of improving it.
did put a face light filter on it
Please ignore sound it was recorded on an H4N, and will be synced up
Advice would be greatly appreciated
Thanks in advance
Here is a link to the footage:
John Fishback
Re: lighting issues as was rushed with set up and noise is visible: http://www.youtube.com/watch?v=73-S6IU0OQg&feature=youtu.be
on Sep 11, 2013 at 1:54:40 pm
Neat Video does an excellent job with noise-also Innobits' Video Purifier.
John
MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.7.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24" TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
FCP-X 10.0.7, Motion 5.0.6, Compressor 4.0.6
Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
Mark Suszko
on Sep 11, 2013 at 4:16:03 pm
The blown-out background contrast can be made a little easier on the eyes by layering two or more identical video tracks, adjusting the highs, lows and mids in each, then adjusting the opacity and blend modes in-between the layers. You can also use a multipoint mask tool around his head and shoulders to separate him from the BH and allow separate adjustments. Are you any goo with the 3-way color corrector in FCP7? How about Apple Color?
Jay James
on Sep 11, 2013 at 7:33:21 pm
Thanks for your response John & Mark will go with Marks suggestion as bit low on funds at the moment - I shall put your advice into action Mark - the mask tool? what is that called within FCP is it under matte? or is it a plugin that I have to download? I'm pretty clued up with Colour Correction
Jay
Mark Suszko
on Sep 11, 2013 at 10:28:15 pm
Search for "Paul Crisp multipoint masking tool free." and you should come up with 8,16,and 32-point versions of the 4-point masking tool.
