importing footage from 2 separate sources with diff settings into same project in FCP7
raju bhai
on Sep 10, 2013 at 10:10:37 pm
Hi, i have footage shot on canon 5d that is h.264, 1920x1080 and 23.98 fps that i am transcoding to apple prores 422 so i can edit in FCP7.
But i also have a clip from a different source that is AAC, h.264, 320x240 and 25 fps. The primary footage is the canon 5d. But i plan to use both in the same project. Should i transcode the 320x240, 25 fps into the same settings as the footage from canon 5d? that is, apple prores 422 1920x1080 and 23.98 or should i transcode to prores with the original 320x240 and 25fps even though the other footage has been transcoded in 1920x1080, 23.98?
Please let me know.
thank you very much!
