Why on EARTH is there not a 1920x1080 AppleTV Compressor Export option?!
David Nussbaum
on Aug 28, 2013 at 11:09:13 pm
Am I missing something here? Compressor beautifully exports in H264 under apple devices in compressor @ 1280x720 but there is not an option for 1920x1080?
I've read of people trying to do it manually but I hear that it does not compress as well!
Can anyone help? So frustrating!
Michael Gissing
Re: Why on EARTH is there not a 1920x1080 AppleTV Compressor Export option?!
on Aug 29, 2013 at 12:00:54 am
If you are using FCS3 then there has been no software development in over 3 years. The product was EOLd two years ago so there will be no update that gives different presets so you will have to experiment and get a good custom setting.
Try changing the frame size in Compressor and adjust data rates and save a custom preset.If you want to then help others then post your settings here.
David Nussbaum
on Aug 29, 2013 at 12:02:40 am
does the later version of compressor have an apple TV device 1920 x 1080 option?
Nicholas Zimmerman
on Aug 30, 2013 at 3:27:57 pm
It sure does. Export a "QuickTime Movie" master file and drop that into Compressor 4. If you upgrade to FCPX it has an AppleTV setting directly in the program as well.
______________________________
FCP X Certified Pro, Level Two
Shane Ross
on Aug 29, 2013 at 12:02:46 am
AppleTV didn't start having 1080p content until very recently. Talking in the past year and a half or so. Well after FCP7 and Compressor 3 were made, and after they were discontinued I think too...
Shane
Little Frog Post
David Nussbaum
on Aug 29, 2013 at 12:08:18 am
ok so what about later versions of compressor? is there a 1920x1080 apple TV H.264 option? I cant seem to find any info on this ANYWHERE.
Michael Gissing
on Aug 29, 2013 at 2:11:12 am
Page 67 of the manual for Compressor 4 has all the info you need.
Rainer Wirth
on Aug 29, 2013 at 11:53:32 am
You can use episode to do your compressions.
It's the best conversion program I came across, worth every buck.
cheers
Rainer
factstory
Rainer Wirth
phone_0049-177-2156086
Mac pro 8core
Adobe,FCP,Avid
several raid systems
