Working with Many AVCHD Clips in FCP
Emma DeGraz
on Aug 25, 2013 at 5:14:38 pm
Hello
I was wondering if people have any tips for working with tapeless footage when you have up to hundreds of very short clips from one event. Do you keep the clips separate, dump them to a sequence, and copy and paste from there? Do you dump them to a sequence, then export them out so they are all in one long ProRes file? Is there a plugin or converter that will merge the clips for you?
Thanks in advance!
Steve Eisen
Re: Working with Many AVCHD Clips in FCP
on Aug 26, 2013 at 3:04:10 am
Why would you want to merge all the clips into 1 clip? Edit each clip separately.
Steve Eisen
Eisen Video Productions
Vice President
Chicago Creative Pro Users Group
Emma DeGraz
on Aug 26, 2013 at 1:17:17 pm
Sometimes I'll have 30 10-30 second clips from one event, and it's easier to quickly scroll through them when it is merged into one clip, rather than having to select each short clip one at a time to view it
Bret Williams
on Aug 26, 2013 at 1:23:23 pm
You could nest them all in a sequence and use that as your source. No reason to export a file and be destructive.
Steve Eisen
on Aug 27, 2013 at 4:45:40 am
Nest the clips or create a sequence called raw footage, place all footage into sequence and scroll away. The last thing you want to do as an editor is to learn bad habits.
Steve Eisen
Vice President
Rainer Wirth
on Aug 28, 2013 at 12:36:07 pm
Hi Emma,
I won't transfer the clips in one big clip. What I always do - I transfer the clips into Prores, but each of them seperate with mpeg streamclip. With this program you can also make one big clip.
cheers
Rainer
factstory
Rainer Wirth
phone_0049-177-2156086
Mac pro 8core
Adobe,FCP,Avid
several raid systems
