memory
bruce botts
memory
on Aug 25, 2013 at 1:30:03 pm
trying to install FC Pro HD onto a G5 with over 900 gigs of memory available and I get the error message that there's not enough memory. I'm not sure how to address this.
Neil Patience
Re: memory
on Aug 27, 2013 at 1:32:24 am
When you say 900gigs of memory that refers to drive capacity.. While that should be adequate the message likely refers to the amount of RAM in the machine.
I think the absolute minimum required for FCP is 2GiGs for working with HD and I think 4 GIGs if you are trying to work with uncompressed HD. (although not sure how that machine would handle those kind of files)
So checking out how much RAM you have would be my suggestion in the first instance.
best wishes
Neil
http://www.patience.tv
8 Core MacPro, Kona 3, Tangent Wave, Mackie Universal Symphony 6.5 FCP7
i7 2.7 Gig MBP (non retina) 16Gigs Ram Blackmagic Monitor Mini Symphony 6.5 FCP7
Tom Matthies
Re: memory
on Aug 27, 2013 at 1:42:38 pm
Which version of FCP are you trying to install? I don't think you can install FCP version 6 or higher on a G5 computer. The G5 has IBM Power PC processors and the newer machines run in Intel chips.
E=MC2+/-2db
Rainer Wirth
Re: memory
on Aug 28, 2013 at 12:40:03 pm
Tom is right!
cheers
rainer
factstory
Rainer Wirth
phone_0049-177-2156086
Mac pro 8core
Adobe,FCP,Avid
several raid systems
