Mpeg Streamclip conversion not recognized
Ray Ellis
on Aug 21, 2013 at 3:48:59 pm
New Member to the forum here. Thanks for everything you have posted so far
Im using final cut pro 7.0.3 and Im shooting with a canon T3i. I am using Mpeg stramclip to convert to Prores 422 LT. When I try to move the converted file into FCP I get " unknow File " and the red stop sign. I also have tried prores 422 and prores 4444 . They all do the same. Can someone help?
OS 10.6 FCP7 just downloaded mpeg stremclip
Thanks for a GREAT forum !
Shane Ross
Re: Mpeg Streamclip conversion not recognized
on Aug 21, 2013 at 4:09:12 pm
Can you play the clip in Quicktime?
Shane
Little Frog Post
Ray Ellis
on Aug 21, 2013 at 6:43:29 pm
No...its says it doesnt recognize the file as a video file
It may be because my original footagewas filmed at 1280x720 at 60fps I will check tonight by shooting a little clip at 1080 at 30 fps
