Final Cut corrupts projects?
dick avery
on Aug 15, 2013 at 6:58:11 pm
Hello, everyone! I desperately need a solution to one problem, so any help would be appreciated.
I got a project and its backups. Video 1080p/25fps. Audio 48/16. All audio files were converted to 48/16 before import to Final Cut. Sequence settings and easy setup are matched to clips on timeline, so there were no audio drifts. Untill today, when i opened a project and all audio suddenly became out of sync. i opened backups, same thing. Once again, it didnt happen before. But suddenly all projects that i open in final cut becomes corrupted. Some audio clips out of sync radically, some in sync. It seems randomly and i cant find any pattern.
Modifying exported xml and importing back doesnt do the trick, because in xml everything set to 25fps/ntsc-false.
Deleting render files and render again doesnt help either.
Where should i start to troubleshoot the problem?
Thank you!
Massimo Alberto Croce
Re: Final Cut corrupts projects?
on Aug 15, 2013 at 8:39:05 pm
try deleting FCP preference. It's a strange behavior.
Video Editor, Colorist, Pro Tools Editor
massimoalberto.croce@gmail.com
dick avery
on Aug 16, 2013 at 8:07:56 am
Thanks for reply. I deleted preferences, but it doesnt help. Same thing.
Rainer Wirth
on Aug 16, 2013 at 6:31:34 pm
Digital Rebellion is your tool. It's worth buying. It's also good for a lot of other things.
cheers
Rainer
factstory
Rainer Wirth
phone_0049-177-2156086
Mac pro 8core
Adobe,FCP,Avid
several raid systems
dick avery
on Aug 17, 2013 at 9:04:12 am
i tried digital rebellion utilities, trashed preferences, removed final cut and all its preferences and renders, reinstall, noting helps. same thing. everytime i open a project or its backups, there are a lot out of sync audio clips. But a couple of days ago those projects opened correctly and there were no out of sync issues.
