playback in canvas
Dennis Roliff
playback in canvas
on Aug 15, 2013 at 5:42:20 pm
Hi all,
I did a forum search but couldn't find quite what I needed. I'm working in Final Cut Pro 7 with some Pro Res LT footage (converted in Compressor from H.264 Nikon D800 footage shot at 720/60fps). I have changed the speed of all clips in the timeline to 40% because this will be a slo-mo piece (will 60fps slowed to 40% essentially give me 24fps?). When I hit play, the footage will playback in the canvas for a while and then freeze, however the playhead will continue playing in the timeline. My sequence settings match my footage settings. Below you can see my sequence settings, RT settings and playback settings. I'm rather new at this so any insight will be appreciated.
Thanks.
Dennis Roliff Photography
Vimeo
Shane Ross
Re: playback in canvas
on Aug 15, 2013 at 6:40:55 pm
Doing the slowing in FCP won't make the moves smooth. You need to use Cinema Tools to CONFORM the frame rate if you want it to be smooth. I have a tutorial for that here:
http://library.creativecow.net/ross_shane/slow-motion_cinema-tools/1
Shane
Little Frog Post
Dennis Roliff
on Aug 15, 2013 at 8:56:08 pm
Shane,
Wow! Fantastic. I had no idea. Thanks so much!
Dennis
Vimeo
Steve Eisen
on Aug 16, 2013 at 12:41:00 am
Change your playback settings to:
Unlimited RT
Dynamic
Dynamic
Steve Eisen
Eisen Video Productions
Vice President
Chicago Creative Pro Users Group
Dennis Roliff
on Aug 16, 2013 at 3:13:58 am
Hi Steve,
Thanks so much for the expert input. I've changed my playback settings as you've suggested.
Regards,
Dennis
Vimeo
Steve Eisen
on Aug 16, 2013 at 3:05:56 pm
Dynamic will automatically adjust to your computer's capabilities.
Steve Eisen
Vice President
Dennis Roliff
on Aug 16, 2013 at 3:09:13 pm
Hi Steve,
Thanks again. This is the kind of generous and expert advice I always count on at Creative Cow. Have a great weekend!
Dennis
Vimeo
