How to black out a spot of a 2 second clip through FCP 7
George Roberson
on Aug 14, 2013 at 7:23:10 pm
Hi, when we were shooting the movie (HD, digital) a gaffer's tape shows up too obviously on a laptop. How to black this piece out (it was a black surface but the tape has slight different color, therefore is noticeable) on FCP7? Is it doable?
Thanks!!!
George
Joe Barta IV
Re: How to black out a spot of a 2 second clip through FCP 7
on Aug 14, 2013 at 8:08:11 pm
Try this, it works if there is not too much movement in the object you are fixing.
Duplicate the clip on a track above it. Crop the clip to a small area right next to the gaffer's tape. Make your cropped area about the same size, a little bigger is better. Then reposition the cropped clip over the tape. Some edge feathering will help too.
Bars & Tone
SALUTE!
Mark Suszko
on Aug 14, 2013 at 8:16:45 pm
You could also try the "limit color" effect in the 3-way color corrector, as well as exporting a still to photoshop, cleaning it up with the clone brush, and then layering that back in with a soft-edge matte.
