format for broadcast tv
Steve Tamou
on Aug 14, 2013 at 1:22:14 pm
I have a 8 minute long video that I shot and edited in HD In FCP7. I need to send it to a satellite tv station that does not broadcast in HD. What is the best compression (through FCP or Compressor) to use for them? And can I send it through email or should I use a flash drive? Thank You.
Shane Ross
Re: format for broadcast tv
on Aug 14, 2013 at 1:57:05 pm
YOu need to ask them what they want. Only they can tell you that.
Shane
Little Frog Post
Steve Tamou
on Aug 14, 2013 at 4:26:55 pm
Thank You Shane.
Mark Suszko
on Aug 14, 2013 at 6:48:19 pm
The most common answer these days is to do an FTP transfer to the station, either privately, or thru a service like DG Systems. Put the video in the format the client wants, or DG can bill you to convert it for you. personally, I'd rather supervise my own conversions.
