external video capture card and settings
Michael Pike
on Aug 10, 2013 at 8:17:18 pm
Hi
I am looking for an 'external video capture card' that will record a screen and sound from a PC or preferable a mac at 30fps and 720p that I can then edit with in final cut pro I have a budget up to £150 but can go further if need be. This is for video game trailer i am putting together which is why i need to be able to record the screen.
Also i have been told requirements for video capture are to have the settings below…
settings
- 720p
- 30fps absolutely steady (no drops from game)
- vsync solid, zero issues from game
- Y,U,V = 4,2,0, do not set to 4,2,2
- 8bit colour space enough, 10bit not essential
- lossless capture essential
How would i go about achieving these settings once i have a capture card?
Thank You
Andrew Rendell
Re: external video capture card and settings
on Aug 11, 2013 at 8:16:07 am
[Michael Pike] "- lossless capture essential"
Lossless capture means your choice is limited to the likes of Matrox, Aja and Blackmagic. Prices start at around three or four times your budget though.
Since your spec includes YUV=4,2,0 (which is by definition lossy), I assume that lossless means no motion artefacts and no apparent loss of sharpness, rather than no compression. That means that codecs like ProRes, DNxHD, XDCamHD and high data rate (say, 50mbps or above) AVCHD should be ok in my opinion (if you're cutting in FCP then it's logical to go straight to ProRes if you have that option).
Michael Pike
on Aug 15, 2013 at 11:28:48 pm
Hi Andrew
thanks for the response when it comes to capturing is my macbook capable of doing this here are its details
Model Name: MacBook Pro
Model Identifier: MacBookPro6,2
Processor Name: Intel Core i5
Processor Speed: 2.4 GHz
Number Of Processors: 1
Total Number Of Cores: 2
L2 Cache (per core): 256 KB
L3 Cache: 3 MB
Memory: 4 GB
Processor Interconnect Speed: 4.8 GT/s
Boot ROM Version: MBP61.0057.B0C
SMC Version (system): 1.58f17
Serial Number (system): W8044HM0AGU
Hardware UUID: 30A70A1F-545E-5E12-8161-F4E64E5B3A0B
Sudden Motion Sensor:
State: Enabled
also would i being able to capture through final cut pro at 60fps?
thanks from mike
