OMF export problem on Final Cut
José Camargo
on Aug 8, 2013 at 5:31:51 pm
So I'm trying to export an OMF sound file from Final Cut Pro 7.
The problem I'm encountering is the following:
At first, the OMF export is going fine, but then it just stops and doesn't fully export every single sound file that's on my timeline, only the first five files or so.
When I open this OMF export on Soundtrack Pro, only the first 5 sound files appear.
I need to export all sound files on my timeline. I haven't muted any of them, they're all rendered and I highlighted all of them before export. What is the problem then?
Thanks.
Shane Ross
Re: OMF export problem on Final Cut
on Aug 8, 2013 at 8:08:10 pm
Are you exporting FULL audio files, not just what's used in the cut, with handles? OMFs have a 2GB file size limit...
Shane
Little Frog Post
Michael Gissing
on Aug 9, 2013 at 6:17:54 am
From FCP to STP you can just send to.
