For Rafael-steps to MP4
Alexander Kallas
on Aug 7, 2013 at 5:20:19 am
In this post http://forums.creativecow.net/readpost/8/1177030
rafael, you displayed this image
I can create an MP4 file using H264 compressor in Compressor4, but I cannot arrive
at your window. Show me your steps please!
Cheers
Alexander
Rafael Amador
Re: For Rafael-steps to MP4
on Aug 7, 2013 at 1:29:50 pm
That's with QT Player.
Just open the Export window (Cmd-E), and instead of selecting "Movie to Quick Time", hit the "Options" button, and select "Movie to MPEG-4".
In the pict you can see the QT Export window below the "Mpeg-4 Export Settings" window.
rafael
Alexander Kallas
on Aug 8, 2013 at 12:01:50 pm
Thanks Rafael, do you have any settings for a PAL video please?
Cheers
Alexander
Rafael Amador
on Aug 8, 2013 at 4:04:35 pm
Well, frame rate: 25fps.
The rest depending of the file size/quality you want.
Key-frames always AUTO, and down in the Video Options: Multipass.
rafael
Alexander Kallas
on Aug 8, 2013 at 10:29:19 pm
Thank you,
of course, but I was thinking about the correct aspect ratio.
Which dimensions will be correct for PAL?
Cheers
Alexander
Rafael Amador
on Aug 9, 2013 at 1:35:41 am
If you want to make a web video from a PAL movie:
- If the stuff is PAL 4x3: 768x576
- If 16x9: 1024x576.
rafael
